Guys I know BMT and DrDrift support the club and im planning on getting my car dynoed and tuned soon just to make sure everything is running well and the mixtures are good
Basically Im just after some places that could dyno my car and sort it out and what sorta prices im looking at
Dr_Drift what would you and the boyz from BMT sting me
I have a R31 Skyline with RB30ET, Standard VLT ECU with cooler, 3' zorst etc...
Thanks in Advance!
https://www.sau.com.au/forums/topic/20568-dyno-tuning/
  • 4 weeks later...
no only 2wd dyno....
but can very easily tune gtr's etc by pulling out the front drive shaft
most places will be anywhere from 100-150 per hour on a dyno, but u gotta remember, is it worth being a stingy tight ass and save 50 and have ya car run like crap or blow up????
no1 rule, always do things properley, cos youl end up havin to fix the cheap crap and end up spending more anywayz...
sam knows his stuff....take it down and talk to him...they r not out to 'sting' any1, they r all good guys down there
https://www.sau.com.au/forums/topic/20568-dyno-tuning/#findComment-485051
Just a quick question about Dyno tuning.....
I have an R33 GTST S2. If I got my unit tuned what do they actually tune? My understanding is that the R33 ECU unlike R32 and R34 is not open to modifications.
So on the dyno what can be done with my car, I am confident that the Factory ECU is set to run very rich, you can smell it!
Do I need a piggy back computer before getting on the dyno or can it be tuned reasonably without the addition of an aftermarket computer?
I am not looking for a 10 second drag car just want the thing running at its optimum.
Ideas anyone?
https://www.sau.com.au/forums/topic/20568-dyno-tuning/#findComment-487396
SLYWPN, Colin got his RB30ET dyno'd at Good Guys Perfomance centre.
He was very happy with the result.
Where we went for the R31 dyno day.
Contact details:
Factory 3/2 Gatwick Road
Bayswater Nth
9761-7261
https://www.sau.com.au/forums/topic/20568-dyno-tuning/#findComment-487450
Well the whole reason im looking to get it tuned is basically just to see what sorta power its producing at the wheels and also just to make sure everything you mentioned as in timing, etc.. is all good.
Davepro perfromance will probably do all that for me so i will probably just end up going in for a power run.
https://www.sau.com.au/forums/topic/20568-dyno-tuning/#findComment-488032
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
