Guys I know BMT and DrDrift support the club and im planning on getting my car dynoed and tuned soon just to make sure everything is running well and the mixtures are good
Basically Im just after some places that could dyno my car and sort it out and what sorta prices im looking at
Dr_Drift what would you and the boyz from BMT sting me
I have a R31 Skyline with RB30ET, Standard VLT ECU with cooler, 3' zorst etc...
Thanks in Advance!
https://www.sau.com.au/forums/topic/20568-dyno-tuning/
  • 4 weeks later...
no only 2wd dyno....
but can very easily tune gtr's etc by pulling out the front drive shaft
most places will be anywhere from 100-150 per hour on a dyno, but u gotta remember, is it worth being a stingy tight ass and save 50 and have ya car run like crap or blow up????
no1 rule, always do things properley, cos youl end up havin to fix the cheap crap and end up spending more anywayz...
sam knows his stuff....take it down and talk to him...they r not out to 'sting' any1, they r all good guys down there
https://www.sau.com.au/forums/topic/20568-dyno-tuning/#findComment-485051
Just a quick question about Dyno tuning.....
I have an R33 GTST S2. If I got my unit tuned what do they actually tune? My understanding is that the R33 ECU unlike R32 and R34 is not open to modifications.
So on the dyno what can be done with my car, I am confident that the Factory ECU is set to run very rich, you can smell it!
Do I need a piggy back computer before getting on the dyno or can it be tuned reasonably without the addition of an aftermarket computer?
I am not looking for a 10 second drag car just want the thing running at its optimum.
Ideas anyone?
https://www.sau.com.au/forums/topic/20568-dyno-tuning/#findComment-487396
SLYWPN, Colin got his RB30ET dyno'd at Good Guys Perfomance centre.
He was very happy with the result.
Where we went for the R31 dyno day.
Contact details:
Factory 3/2 Gatwick Road
Bayswater Nth
9761-7261
https://www.sau.com.au/forums/topic/20568-dyno-tuning/#findComment-487450
Well the whole reason im looking to get it tuned is basically just to see what sorta power its producing at the wheels and also just to make sure everything you mentioned as in timing, etc.. is all good.
Davepro perfromance will probably do all that for me so i will probably just end up going in for a power run.
https://www.sau.com.au/forums/topic/20568-dyno-tuning/#findComment-488032
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
