hey i got a msg from my mate about a cruise
Date: Friday 15th
Meet: Pat Goodridge Hockey centre car park on selby street in jolimont.
Time: 8:30pm to depart around 9pm
he said let everyone know bout this cruise sooo i hope it turns out well if u are on other websites and can advertise this would be much appericiated
cheers every1 hope to see yaz there
https://www.sau.com.au/forums/topic/205680-friday-15th/
i belive soooooo just left him a msg soo once he is replied i let ya no,,, i think he has organised a few evos ect ect soo goin to be a fairly mixed cruise i think
YES MAPS PROVIDED BIT OF HILLS AND SOUTH OF THE RIVER :(
Edited by munazza
https://www.sau.com.au/forums/topic/205680-friday-15th/#findComment-3640330
Contemplating it.. I have a working gearbox now so pretty keen! Depends on the extent of the hills bit.. I hope it's not up that stupid hill and back down the single lane narrow assed road with mega dropoffs and hairpins every 50m!
https://www.sau.com.au/forums/topic/205680-friday-15th/#findComment-3644695
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
