  • Replies 73
Hehehe, I've had a quick run with a GTS.
It was a rolling start from about 20km/h to 140km/h.
There was nothing in it upto about 110km/h then I was just (and I mean JUST) pulling away.
I was totally shocked as was the bloke in the GTS :D
At that stage I had a turbo back 3 inch exhaust, 12psi boost, and a pod with CAI !!
Oh - I've got a 1995 GTS-t.
Not bad for a car that is about 1/4 the cost ;)
J
https://www.sau.com.au/forums/topic/20574-gtr-vs-holden-gts/#findComment-431047
The Hsv r very crappy cars, they weight too much and dont have enough power holden really need to get them right. GTS-t should be able to hold them with not alot of mods.
The ls1 350 r around 300hp (if i remember right) they should be Mid 13second 1/4mile but they never are more like mid 14, so GTs should hold it and GTR should take it
All depends on drive, weather condition but the skyline should have the upper hand
https://www.sau.com.au/forums/topic/20574-gtr-vs-holden-gts/#findComment-431083
Originally posted by playa
JAY95R33. lol u were pulling from 110km/h onwards... Geez GTS's aint that bad are they??
Yepp just. When I say just I mean about half a bonnet length !! So there really wasn't anything in it.
The GTS's are very heavy. Something like 1680kg's (someone correct me if I'm wrong here), compared to the GTS-t's at about 1380kg's.
https://www.sau.com.au/forums/topic/20574-gtr-vs-holden-gts/#findComment-431096
Originally posted by Soulja
By the way if it is a mod Ls1 with AMerica Mod Parts then yes he could wipe the floor with gtr
You mean it'd win if it's against a standard GT-R...
If on the other hand, the GT-R is modded with Japanese parts, it's shit over the GTS.
https://www.sau.com.au/forums/topic/20574-gtr-vs-holden-gts/#findComment-431343
Originally posted by AVENGE
I dont care if your mod parts come from Uranus, on the street a GTS will never beat a GTR due to traction alone!
If anybody cares to prove this theory wrong, lets go! :D
oK TIME TO PROVE U WRONG hehehe (sorry about caps)
Lingenfelter Installed Engine Packages
1997-2003 Corvette Twin Turbo LS1, ZO6
550 BHP / 550 lbs-ft of torque
500+ rear wheel hp
Includes:
CNC ported cylinder heads
Three angle valve job, checking of spring tensions & heights
LPE custom camshaft
Two true ball bearing turbochargers
Two high efficiency air to air chargecoolers
Custom molded Samco silicone air ducts
4 into 1 custom exhaust manifolds
Two turbo outlet adapters
Turbocharger scavenge pump
Turbo oil drain reservoir
Two K&N 360 degree conical air filters
Heat shields and stainless clamps
Professional installation, testing and tuning
GHL stainless steel exhaust system
Turbocharger water feed and return hoses
Turbocharger oil feed and return hoses
Gaskets and fasteners
Chassis dyno report
2 year/24,000 mile warranty
This kit is build for corvette but as the GTS has the same block LS1, it will fit with a few minor mod.
I dont think you could get something like that in australia for a hsv :bahaha:
P.s This is just one of the many kits
350 CID LS1
350 CID Supercharger
383 CID LS1
427 CID LS1
550 HP Twin Turbo
650 HP Twin Turbo
725 HP Twin Turbo
and yes im pretty sure 1 of this kit would give a Jap Mod GTR a run 4 its money (who would win would be done to spec and dirver)
https://www.sau.com.au/forums/topic/20574-gtr-vs-holden-gts/#findComment-431415
no they arent drag slicks car, they r street vette with street tyres. i was just saying if a kit like that was add to a hsv gts it would beat a gtr easy but then again a mod gtr is hard to beat (i have seen some really nice mod R_34)
If i remember right The 8second vette with the trubo kit had street typers (or maybe it was the 9 second)
again just tring to prove a point not up for other flame war
https://www.sau.com.au/forums/topic/20574-gtr-vs-holden-gts/#findComment-431471
yes all that can be done no doubt with even street tyres i still believe you, but yes these kits cost money, and these cars are set up for drag racing with solis rear ends and usually mini tubs, (not all some) the most basic superchargers kit and all the essentials on a ls1 sets you back say 8g, spend that same 8g on a new r34gtr (apples for apples both new cars) and i bet the gtr wins again and i dont care if they are jap, german, english or aus parts...... Also dont forget there is about 30-40GTR's in japan that run low nines or 8's with street tyres... Not bagging the gts had one for a while there well dad did but, c'mon this thread is ridiculous its apples n oranges chalk n cheese one is a purpose built performance vechicle and one is a performance vechicle made from a purpose built fleet car, both have strong and week points but no need to have stupid arguements and prove you wrongs about them..
https://www.sau.com.au/forums/topic/20574-gtr-vs-holden-gts/#findComment-431494
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
