Rich Flavour, if you want to get a lot of attention here, put a Atmosphere Blow off valve on, and then start a thead asking why your car stalls a lot.
Either that or start a Plumb Back BOV vs ATMO BOV thread
haha
haha
your a f**king idot mafia
haha ok flavour. the simple answer is YES.
THE ONLY difference with the s1 and 2 turbo is the exhaust wheel, the s2 is 'normally' a nylon item.
but the stud pattern etc is exactly the same.
basically the same, so hardly any air flow differences, soooo your stock s1 afm is fine :)
yes s2 is nylon and s1 is steel but its the intake wheel, not exhuast.
ok, you sure? at one stage i had one of each on the bench, took the compressor covers off to compare them and the wheels were different from each other. different number of fins, one was silver alloy and the other was a black wheel and had a plastic/nylon feel to it. when i asked the question i was told the series 2's had a plastic/nylon compressor wheel.
i dont know u maade mistake but the compressor wheel is nylon not the exhaust wheel, havent seen any type of nylon to withstand high exhuast temps before lol :)
rofl, you're not serious are you?
I took my SII turbo off and the wheel looked and felt steel to me. I'm pretty sure the nylon spacer is behind the wheel.
i took mine of too and its definitely all plastic/nylon, i wouldnt understand the point of having a nylon spacer, its nylon to make it lighter...
yes, i started a thred about it a while ago.
http://www.skylinesaustralia.com/forums/St...-s-t183562.html
i didn't go as far as pulling the wheels off though.
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
