Hey there people.
I just recently bought a 1994 R33 Skyline.
It has a Big HKS exhaust and a Greddy Intercooler.
I had a bleed valve fitted and it is runnibg at 11psi, punching out
187RWKW.
I was just wondering what is next to do to it. I just wanna do it and
not have to worry about replacing stuff over and over.
I was hoping for about 350-400+ ATW. The car is off the road for some
of the work to begin.
I am not made of money and I saved for years for this so I am
hoping to do the work myself.
Can you please help me out.
Thanks,
Shaun
https://www.sau.com.au/forums/topic/205754-what-to-do-next/
350-400RWKW you wont get for any less than $5000- $10000+ on existing engine....
your next mod should be ECU related, either replace with full aftermarket set up and tune $1200-$$$ or look into something like a second hand SAFC piggy back controller $4-500 tuned, good tune on full replacement ECU with 14psi should get you 50-70 extra RWKW depending on the condition of you engine.
you will get better responses in the forced induction section though..
May-be a MOD can just move this thread..
https://www.sau.com.au/forums/topic/205754-what-to-do-next/#findComment-3642945
350-400kw atw?
Prepare to spend big (c.10-15k) and put up with lots of little issues- especially if the car isn't in tip-top condition. The difference in cost between 250rwkw and 350rwkw is big.
For that power you'll need a forged bottom end, head work (cams, port/polish, valves+springs), fat ass laggy turbo, reworked fuelling system, Power FC, twin/triple plate clutch etc...
I could go on and list the other things, and some of the problems that might arise from working the car so hard (such as maintaining traction)
If you're prepared, patient, well planned, and have the cash you can build an awesome machine. Do some searches in forced induction and drivetrain sections too.
Good luck ;)
Edited by R338OY
https://www.sau.com.au/forums/topic/205754-what-to-do-next/#findComment-3643081
