Make: nissan
Model:skyline r32 gtst
Milage:123,xxx
engine: rb26 twin turbo (out of a r33 gtr)
Transmission:r33 gtst man with jim bery full monty clutch (all fitted oct 07)
driveline: one piece tail shaft with big uni's (fitted oct 07) low km diff just fitted ( jan 08)
brakes: sloted brakes on front with new pads just fitted (jan08)
Colour: black
Car Engineered with all paperwork.
Car currently running 14psi boost with reco'd steel wheel turbos (nov07)
also had starter recod a week ago,with 700hp fuel pump
Serviced every 5000k's with Royal Purple Engine Oil & k&n oil filter.
Complied?yes
RWC supplied?yes
Currently registered?11/08
Price: dropped to 14,000ono
Contact:anthony sms or call on:0433201554
Looking for a quick sale, as have completely lost interest in the vehicle due to amount of money spent. recently spent $6000 just in transmission area. Runs great, will not dissapoint.
http://img40.picoodle.com/img/img40/9/8/8/...ARm_d6716a1.jpg
http://img40.picoodle.com/img/img40/9/8/8/...NTm_1e6312a.jpg
Edited by anthony84
https://www.sau.com.au/forums/topic/205764-r32-gtst-with-rb26dett/
reduced to go to a good home.
I have lost interest in this car, also adding to that train of thought is the money that i have spent on this car and know i wont get anywhere near this back... : (
Im looking for a van to do my own business in courier work,
thanks
Edited by anthony84
surprised this hasn't gone already. gtst's with rb26 conversions absolutely fly. and great fun to drive.
at 14k, that's a bargain. the engine alone is worth 4-5k, and that's out of the car, not installed.
if i hadn't already put a rb25 into my r32, would have just bought this instead and saved me the time and effort
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
