definately agree with the R31. its probably going to be faster than an non-turn R32 or R33 and is a shitload cheaper to buy and maintain
plus its got old-school cred!
if you must get an R32 or R33, then look at the R32GTS25 which has the rb25de as stock. they are all 92 or 93 models i think
R32 GTE - RB20E - 130 ps (96 kW) - 181 N·m (18,5 kgf·m)
R32 GTS - RB20DE - 160bhp (114 kW) - 186 N·m (19 kgf·m)
R32 GTS25 - RB25DE - 190 bhp (140 kW) - 255 N·m (26.0 kgf·m)
R33 GTS - RB20E - 130 ps (96 kW) - 181 N·m (18,5 kgf·m)
R33 GTS25 - RB25DE - 200 bhp (147 kW) (with VCT) - 255 N·m (26.0 kgf·m)
R33 GTS-4 - RB25DE - 200 bhp (147 kW) (with VCT) - 255 N·m (26.0 kgf·m)
The R32 is a bit lighter, and I know first hand that it handles great, we don't have R33's here yet so I can't really compare. I know the R32 GTS is still a sporty car, doesn't have the kick of the GTS-t but then I guess thats the point of a first car.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
