seen a red r31 wagon black wheels turning off salisbury hwy near red rooster sticker on back window "madaz" is this ur car "madaz" on this site even if its not still looked really good :)
woulda been kev's old wagon......believe he sold it over the weekend
but yes....the same RB20DET wagon :P
but yes....the same RB20DET wagon :)
Ahh, I was wondering why Kev would venture out to the ghetto :P
So his Stagea (dream) would be getting closer
You serious?? Sweet as, one of the best movies ever made!!
sorry yeah Fox Clasics
http://www.yourtv.com.au/guide/index.cfm
FOX Classics
(112)
6pm
Everybody Loves Raymond
6.30pm
M*A*S*H
7pm
7.30pm
The King of Queens
8pm
Scarface
spotted like 3 stagea's on my way home from work up greenhill road one was a P plater gave a wave got a confused wave back
may have seen Mel Pauly's me on Kensington rd cant think of any skylines that i saw
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
