also saw that blue 34 gtr and the white 33 behind it going down north east rd. look good
also saw a maroon 33 with black rims NO front bar and had a cooler and oil cooler hanging out the front. on the north east rd
spotted a black 33 at enfield cemetry. cant memba the plates but it had hydraulics, a chrome badge of a lady on the bonnet. sat very low. quite impresive :D also seen a silver 33 at the front gate when i was leaving!
Yes that silver 33 was me, i also saw that black one, the plates where IAMLW2 and was very low indeed.
there was also a grey 32 4door there too.
spotted blue r34gtr, plates BNR34 overtakin me on north east around 330 and turning onto sudholz rd i think...quite a machine
also a light blue r32 vertix kitted, further down north east rd soon after..
2nite a very low silver r33, full kit, no wing heading up mckintyre, just after 1130pm..
Spotted MissR34 and Damo34 today :bunny:
-D
[/qu
ah so u didnt see the air bag or hydraulic suspension in action on the black 1?
Spotted today MR R34 parked in the u-park on grenfell street, looks sweet as from the back, a midnight blue 33 GTR on south road just up from sturt road and then a black 34, looked like a GT-T. Also on south road, was stopped on the side of the road just down from Lander road in o'halliron hill. Also a very nice black S15 pulling out of officeworks on beach road in morphett vale. Really nice rims.
spotted cara twice yesterday. Once at about umm 1ish walking along sir don drive and second later at night drove past me on sth road.. whats with all the vinyls? :S
Hawtness! I saw them earlier today and its making me consider calling the dude and getting some myself hehe
-D
haha wiked at least someone saw me lol im happy!!!
Hey Flick i saw you the other day turning right onto Grand Junction rd around 8am then the same day saw u driving on south rd around 7pm hehe
Yesterday spotted a silver 32 GTR turning right off Panalatinga Rd around 6pm then straight after a silver Stag going past me in a hurry - plates XOT-xxx. Followed him to Beach Road. And earlier on I think I saw DSTROY (think that's the plates), black 32 GST-T (or more like GTR!) on Byards Road, Happy Valley.
Edited by 32godzilla
sounds like me. i also saw the gtr going the other way from me on north east rd
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
