im at regency tafe atm mate, so i turn off to go into regency, thought it was a bit random you were on the same road, at the same time and i didnt see you! there is a purple 180 and a grey 32 gtst i have seen in the car park near the plumbing section, ! anyone???
I go to regency tafe too. My r32 with vertex kit is always parked in front of electronics section along with a charcoal r33 (i know the guy, he's occasionaly on this forum - so he said), silver 4-door r32 and a black stag (I only see it on tuesday afternoons).
I was at trade school last week, I saw the silver 4 door 32.. if its the one im thinking of it has mesh rims and a spoiler. It looks pretty dope.
I was in the Laurel that got beached on the speed humps..
ohhh nooo! im beached as brew!
hey man, might be an idea not to post where imports are regularly parked as im sure car thieves have before and probably will again read these forums. Not having a go or anything but would just hate to hear of another import being stolen so dont think we should be giving these people exact locations to go and find them.
On topic, yesterday at Jb modbury, silver 34, nismo kit, pretty sure th same wheels that Luke(ENR) has on his 4 door. Looked tuff.
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
