im at regency tafe atm mate, so i turn off to go into regency, thought it was a bit random you were on the same road, at the same time and i didnt see you! there is a purple 180 and a grey 32 gtst i have seen in the car park near the plumbing section, ! anyone???
I go to regency tafe too. My r32 with vertex kit is always parked in front of electronics section along with a charcoal r33 (i know the guy, he's occasionaly on this forum - so he said), silver 4-door r32 and a black stag (I only see it on tuesday afternoons).
I was at trade school last week, I saw the silver 4 door 32.. if its the one im thinking of it has mesh rims and a spoiler. It looks pretty dope.
I was in the Laurel that got beached on the speed humps..
ohhh nooo! im beached as brew!
hey man, might be an idea not to post where imports are regularly parked as im sure car thieves have before and probably will again read these forums. Not having a go or anything but would just hate to hear of another import being stolen so dont think we should be giving these people exact locations to go and find them.
On topic, yesterday at Jb modbury, silver 34, nismo kit, pretty sure th same wheels that Luke(ENR) has on his 4 door. Looked tuff.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
