Spotted a silver 32 GTR tonight going south down south road near the strathfield at black forest, looked clean. This was around 5.15pm
Also a grey 32 GTR heading same direction near flinders with a defect notice on the front, gotta suck! Had BB plates. Pretty sure it'd be the same one i see going down daws road in the morning. Would have been about 5.45pm today.
Spotted a Bright pink, and i mean bright R33 skyline driving down frome rd in town friday, anyone on here?
maybe...just pop in on the rare occasion to catch up on the cutthroat comments, wouldnt want to miss those
Edited by NIZMO-R33
spotted a red and black R31 Coupe, flew past didnt see much else...lol
spotted a very nice looking blond driving a White R33GTS-T with chromies in seaford today, she was right on my ass...lol gave her a wave , she even goosed it at the lights passing that truck to keep up to me , (damn traction control grrrrr and full boot/full tank of fuel. to heavy had to shift at 5k to stop traction light..lol nice to see a women can play too..lol, her car sounded good , heard the woosh..lol) anyone on here ?
ahahaha...that would be alicia,and shes not on here.
i think i used to help you out when i was at autobarn too haha!
Hahaaha yeah... but you gotta admit a bright pink car is likely to get plenty of attention!!
Don't worry about the keyboard warriors....
Spotted this morning on south rd around 8am white RS4 stag in traffic.... tidy.
Spotted a wine red R33 down South before. It has propably the worst front mount intercooler setup I've ever seen. Aftermarket front bar with a piss weak tiny intercooler literally cramed in and hanging by 1 bolt. It looks so small, it looks like a side-mount! The body kit has also seen better days.
It's for sale, too! $13k.
I know the driver!
I know the driver!
amps could be over heating. If you go from having sound to no sound, id say that is a good chance. Or might not be grounded.
If you think it might be overheating, try it, play ur system until it does it, turn it off for 15 - 20min and than try again. If that is the problem than it is just poor air ventilation.
Where are the amps installed? boot or underneath the seat?
its not that off maroon colour one going around here is it?the one with the 400R front bar on it?and a chik drives it?
Spotted.... a bunch of SAU-ers at Villis then at BP.
Spotted various Skylines at glenelg........ black R33 series 1 with shiny cannon, dark coloured probably black R33 with drift lip spoiler, silver R32 GTR V-Spec II, a couple black R32s, black R31..... and probably a few more...
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
