spotted a white R34 kitted up on taply's hill rd that looked like howie's avitar? not sure cause it had sorta supra trolly type wing on it but the same black bottom stripe on the lower front bar?
gave a wave, nothing ?
Definately wasn't me buddy... wasn't around that way, and no wing.
Oh.. spotted ecenshu around my area, wtf double defect bro??? damn.
spotted a white R33 coming north thru seaford tonight before sundown ? gave a wave nothing?
spotted a black wet R32 coming out of the BP carwash on beach road, wave = nothing as I was pulling in to BP ? guy driver and a chick in shotgun?
spotted another black R32 dry coming down beach road towards the beach when i was pulling out of BP, wave nothing, ?
and a frenzy of P plate commys heading around the beach doing burnouts on every street corner. assholes get a life Im not impressed
same with the guy in the landcruiser tailgating me so close I couldnt fit a peice of paper between us. all the way from aldinga to the expressway.trying to close the gap so close to try to scare me.. nice try Im used to bad drivers from the states.plus if he hit me Id be getting a new body kit..lol the asshole drivers are out tonight..just my two cents worth . sorry
Spotted your missus again today Kristian, this time leaving TTP in the TypeR...
Also spotted Ben in the 260 headed towards TTP, gave him the thumbs up but I was in the girlfriends Pulsar. Hope the copper on the bike didn't give you any greif!
Ben says cop??......... what cop??!! lol and he said sorry he didn't see you , he was in his own little world.
spotted a black stag in town last night series 2 traveling north on (insert road name here :S)
And a White series 2 stag with zhorts and 34 gtt wheels on the parade, must be a freshy cos it has those new plates.
Commy's are the RCK cruise guys...
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
