spotted way to many cars today to list on my way to and from Gawler and ingle farm today.
but two come to mind
one yellow r34 with a complete body kit, bonnet too, at the dyno on south road by Castle plaza ?,a really hot chick in garage kept my attention more then the car..lol :)
but the car looked like the one Bitz uses in the ad for ADR bonnets ? sweet looking for yellow R34
and i followed down o hall hill and pulled up next to a real nice R34 GTR V SPEC II with some bad ass wheel on it. in bayside blue. but to tell the truth the two guys in it were arrogant tools, I pulled up to say hello and waved. they just fobbed me off like a GTT was a magna shit box not Skyline, he kept boosting near me, but acted like a tool? and up himself. if your on here sorry but you gave off a bad impression of yourself. :) and you drive erratic , wont be long before the R34 is in the trees the way you drive.
spotted scott's car at aussie discounts yesterday but couldnt see you anywhere around
black 34 4 door (thought it was andrew for a sec when i heard turbo and auto, but when i looked up it wasnt lol) while washing the car next door at the dazzlers
and had a silver stag with meshie wheels behind me on brighton rd at brighton yesterday bout lunchtime (and cutting thru the backstreets to get around the roadworks). when ya went round onto morphett rd it sounded alrite mate :D
white r33 with black bonnet smashed up on main nth rd at 7.45am looks real bad feel sorri for the owner it was hit from front and the rear hope ur ok mate
Edited by darrenr33gtst
Spotted IGTR32I along morton road last night at Christies Downs. I was the tall dude walking along with the blue t shirt on lol. You still running the stock GTR bov's? I've never heard them from outside the car before... sounded like you were! They sounded pretty decent.
spotted chad this mornin bout 10 (roughly about that time) at the lights by finders uni. i was heading up the hill. did toot but ya probably didnt see me
Na didn't see ya mate, i'd only just got out of bed, so my eyes were still half shut, lol.
you did bloody well to spot me - I've only driven the car three times in the last few weeks!!!! Took a mate out to scare him........yep, worked!
I'm not surprised you scared him ;) that car is metal, fasted car i've ever been in :)
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
