Didn't see ya sorry ... plus I'm usually in my own little world going to work.
Paint job is coming, but I need to fix/replace my turbo first now :thumbsup:
I was sitting on Unley Rd about to cross onto Pultney St, a few cars back from the front so you wouldn't have been able to see my car :)
(besides i was in the SP23)
Dunno. :thumbsup: But I did get it second hand despite having it checked out by a local shop. Stag gets oil change every 5,000kms. I baby it around all the time, just cruising. Running under 10psi boost. Garrett core and all, never suffered any abuse. Developing a slight rattle/dry noise. No oil leak or smoke. Just slightly noisy at the moment. I'll know more after I've seen ATS ... but at this stage they might be rebuilding it for me. :)
hmmm i got a turbo here thats got problems too. seems all good and no smoke either till you get the boost up. think its bearings are shot as it makes a noise under boost and looses boost under top end revs. lucky i had another layin around i slapped on
not good and not happy.
spotted a grey 4 door 34 low n with p plates doing about 80 up brighton road at about 6 PM
SLOW DOWN W4NKER
Spot on Benzender I to have a R34 silver in colour and low , but that was not me you've seen but ive seen the the same car in the mornings speeding down brighton rd. wish the person doing it would stop it gives us all bad reputation and makes people think its me because we have the same car.
Finally spotted you nightcrawler.
going through a round about. heading into northgate. around 7pm. I was heading nth east straight through to Oakden.
Was right next to you. not sure if u saw me tho.
damn didn't see you mate ... I was bolting home and running late for dinner ;)
Whats happened to your turbz roo?
Today driving up the freeway to Mt Barker to work. Red VS Commie pulled up along side me sporting a SAU sticker on rear right window got a wave as he undertook me. I drive rather casually up to work in the morning if your wondering why i wasnt sitting on the speed limit lol. Who was it?
was it a ute with average paint and gay kit? sounds like my old ute
picture of it in its better days
spotted a silver r33 gtr on salisbury highway this morning
and a white stag somewhere cant remeber
and vange on prospect rd going home
i'll just claim that one ey ... i haven't been spotted in a while
Spotted a Deep Purple Legnum parked in front of my house last night with a Iron Chef Imports sticker on the back.
That's the 3rd car in my street with a ICI sticker on it! Kristian's consuming the street.
Also spotted a R33 GTR, Midnight Purple going down South road yesterday arvo.
Spotted to ugliest R32 at Westlakes today!
Silver, big chromies, some gay wing, black bonnet, chopped up front bar with massive front mount hanging out and a GTR badge on the front. f**k is was the gayest thing I've seen
lol yea ok i dont think anyone will know !!
you had a FAGadore ute matty??? ;)
you are now DISOWNED
+ 1
:P
also spotted my car at Claudes Trim Shop getting the boot finally finished..........wooT!!!!!!!!! :huh:
Spotted today on way home from work, an r33 orange with black roof and bonnet with a white r33 behind it waiting to turn right from waterloo corner road onto port wakefield road!
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
