Regularly spotting Matty T's truck in the ETSA Depot lately ;) Looks nice and clean matty
Also spotted Arj Barker in NAB branch today getting a replacement card for his bank account :rofl:
Also got his mobile number through sneaky means - prank calls anyone? :D
thats where im based at the moment lee, and trust me, dont look close up lol. had to park closer to the gate today cos the other section had an early start
occasionally see you too, mainly in the SP though
Yeah im in the SP23 most days as its cheap on fuel but still fun enough to drive
hmm spotted a white r34 with gold rims on salisbury hwy me thinks
also spotted me underneath my car trying to cable tie my cold air intake back on along with the stone gaurd that decided to come loose at the port adelaide super cheap auto store :P
After picking up my car again from EP in salisbury I spotted a white r33 with black bonnet on salisbury hwy, a blue r34 coming pretty fast off grand junction rd near arndale and a burgandy r32 at the car was on port rd had a car toys sticker on it.
also spotted me underneath my car trying to cable tie my cold air intake back on along with the stone gaurd that decided to come loose at the port adelaide super cheap auto store ;)
You go to Super Cheap? :P
Trying to better the Silvia :laugh:
I keep spotting a white M35 in my area (Golden Grove). Anyone on here?
I would say that is my wifes car good spoting was it the same as the one in my profile?
spotted ruby in the black stag last nite at south/sir don lights. by the time i worked out it was you it was too late to wave, but i dont think ya saw me anyway
Err, nope. I was on my way back from TAFE. Still tired from the roadtrip so I'm not paying attention much :D
But :banana: anyway!
Might be at the BP tonight with the biker lads. Shall I be seeing you there?
Edited by RubyRS4
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
