Spotted a black 260RS with the number plate...surprise surprise...[260RS] driving down North Terrace this arvo, I was a few cars back from you when you turned off. Aside from that, I managed to sneak into town in the N1, park on Pirie Street for an hour, drive home via Rundle Street, and still not see a single Skyline lol
You biyatches better be coming to All Japan Day. The list of entrants is off its lips.
chef, ive gota silver 260rs and ive got those plates :S lol... theres a black 260 with bitsus...???
Spotted you near the uni today mate
i was in the Ford Territory (Govt plated)
krishy did u hear my drony as exhuast !! no car or muffler :( it rusted threw :S
sorry no i didnt hear that Adam
had the beats cranked and windows up
stock ford speakers :(
Edited by Krishy
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
