Haha, awesome! Atleast you've got the missus off your back now from the "unapproved purchase" :P
Yeah money's back in the account, so everything's great until I get trigger happy on the bidding button at auction again. Spotted a very tasty manual JZX110 last week... :D
I have to say, I really liked that Cedric though, might get another one.
"Other chef", that would be the one then, bit had to spot the difference in rims while they were moving, but I was pretty close haha Really nice looking car.
OG CEDRIC = MAD RESPECT :P
bring in some k cars, honda beat cant be beat :huh: well unless it involves a race with something faster than a donkey
whoops thought this was wasteland not the semi wasteland :P
Edited by Inline 6
Spotted a maroon 33 turning onto Target Hill rd around 4pm, and a black 32 on Main North around the same time heading north. Black 33 turing onto Kings Rd from Main North about 4:30pm and a white 34 around the same time. Also that sweet 32 GTR at Parafield, plates BNR 32.
Spotted a R32 GTS.T driving down lonsdale rd/brighton rd at about 5pm on my way back from Hounslow Crash Repair (HCR) today, had a Sinergymotorsports.com.au sticker on the rear window and S.xxx xxx style plates.
Anyone from here? I basically followed them the whole way down the hill lol
I think i spotted you driving down Brighton rd, do you have different number plates than you had before? I was driving up the hill in my bright red hilux.
No worries mate, sorry I had to leave so early, now you have all the parts should be a breeze once we sort out the dump pipe clearance issue. Still can't work out what's going on there :/
not a problem mate. clearance issues are a bit boggling, cant figure out whats going on there, never pulled the studs, and im having trouble seeing how it even fit on the jig. :huh:
still an awesome piece of gear though.
dave and dump pipes are a match made in heaven
haha, sad part is i actually spent a decent amount of coin on this one too.
It's the studs Steve, they seem to be longer than standard. Seems they've been replaced at some stage. No matter, Andrew is hooking me up with suitable replacements. Oh, and my exhaust is going on Friday!!! :huh:
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
