spotted what looked like ruby on tapley hill in the black stag
also a grey r32 on a tow truck, slightly stripped, no boot lid etc.
Nope. Black Stag has trans problems. Parked it at home after work Tuesday and haven't driven it yet since.
Guys at work are confused :) Drove the black stagea Tuesday, silver stagea Wednesday, and R33 today :)
Edited by RubyRS4
That may have been me if it was after 4.30 as i was going to pick up my new cooler from Port rd.
Yeh the GTR front bar is still on my car. :) Even thought my driveway sometimes doesnt agree that it should be on there. Haha.
man your driveway but be bad. i got out of mine when it was at it lowest. was touch and go tho. that was coilys wound down and helpers removed. was almost tucking rims that day not just tires. :)
Edited by sneaky1
i know a few ppl with gtr front bars on their cars so ya not the only one and i had one on my 32. the new owner still has it on there.
i know a few ppl with GTR bumpers on their 32s, outragesly they have entire gtr body kits and rb26s to :) hell im 1 of em
Edited by Inline 6
Saw GOD2ILA (32 GTR) at coles car park glenelg last nite! Nice car :)
Seen this parked in the ultra tune on south road just down from turbo tune, seen it there a few times, owner works there possibly... And yeah, tough looking car..
Oh and do u live on states road near morphett vale by any chance? Seen a car like the one in ur display pic that looks almost exactly the same.
PM'd lol!
Spotted "CHASER" a silver chaser on goody rd this morning, (waves exchanged) sexy looking car u got there!
U on here?
spots from yesterday (im slow),
the former viva garage gtt at wilsons parking on hindley, a red (yes, actual red)32 out front of the o'connell bakery at about 9pm, and a silver stag at the main north/uley lights heading south at about 9:30...
Just spotted a really clean FD series 6 i think on clare's main street lol
spotted a r35 gtr on o connel street..licence plate gtr2009 or sumfin like that..
blew a load in my jocks...lol
there is nothing wrong with blowing your load after seeing the most awesome creation :P
spotted MSTR32 on five ash drive about 3:30 this arvo. gave ya a flash of the spotties and the thumbs up as i was heading the other way
did you blind him and send him spearing off the road?
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
