OMG! so your saying YOU actually do like to suck a big long wang??
must have been that dislexia playing up, u know that dislexia that makes him exempt from responsibility for anything he says, kinda like what sled does.
so let me get this right mods, if people use insults against people the mods dont like, it's ok? if mods insult members they dont like it's ok, but if someone the mods dont like simply disagrees with them, they get banned?
ok got it.
it should be put in the SAU guidelines, "suck mod cock or ban"
ok got it.
you and ted would be the first 2 to line up
spotted miss r34 fail at parking in maccas murray bridge last night.
did you take up 2 parks because you suck at driving? or because with the extra width from all the vinyls you cant fit in 1 park?
im going to say its both.
im not envious btw.
saw like about 400 skylines in the last week.
all shit.
Sled you officially have my permission to ban both of those tools for life .... your call mate. We obviously track their IPs, so they can never re-register without us knowing.
mate I've been insulted by professionals unlike a couple of pea brains like you two.
Look back at past posts and you may understand why he's no longer welcome here....not because he called me a name, but because he upsets everyone on here......grow up and stop sufferring from little man syndrome.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
