"nizmo" turning off main north onto uley at 12:20.
gunmetal r35 turning off main nother onto elder smith at 12:40.
red zenki s14 with tri spokes and a carbon bonnet in north adelaide at 1.
Spotted my White R33 at Horsepower In a Box this arvo....nearly finished, hopefully have it Friday night - fingers crossed.
Spotted my Boss's Silver Stag out the front of work, and a Red Stag also out the front of my work when i called in there on my back from HPIAB.
Edited by Aberax
There's a white s2 R33 GTST that drives up my street in Newton every day - obviously lives around the corner from me , mostly standard except for lowered suspension, great sounding exhaust, origin (i think) rims, and - (don't know if you're on here - if you are; lose that silly high pitched BOV! You're calling out for a canary! -and it sounds like shit) Other than that - bloody nice car.
also spot another white S2 33 GTST most mornings on Newton Rd around 8-8:30am, Impul rims, looks nice! this one belongs to a member here i believe - cant remember which username!
Would this be the one?
Often see a black 33 on st bernards/newton which I guess is probably you :(
And a black 34 at an office building I was working at today on fullarton rd.
Edited by nicr4wks
Often see a black 33 on st bernards/newton which I guess is probably you :banana:
Thhhaaats the one!!!!! nice car mate!
nah the black one in my profile photo belongs to a mate of mine - I have the white one in the far background of that shot (gotta change that image!). But yeah anyway, I usually spot you in the mornings when I'm on the bus (sadly, its where I do most of my spotting - I hardly drive my 33 as I work in the city! :dry: ). But I do reckon I've driven past you in the opposite direction on a weekend some weeks / month or so back on Newton Rd or somewhere around these suburbs!
Black 33 & dark coloured 34 corner of Glynburn & Magill about 5:40
White 33 turning on to hanbledon rd? off newton just before 6pm, realised a the last second and chucked a nod but i think it was too late!
saw a dark grey 33 4 door with a cannon and stockies i think on the southern express way this morning between 7:30-8:00
looked like it had for sale on the back in white texter but it was really faded and hacked away
Spotted what looked like Luke's R34 4 door on West Lakes Bvd today around 4ish.... only had an asian girl driving it!! Exactly the same stance, same colour, with fat wheels and the little carbon fibre boot lip on it too..... weird!
Also saw the same white Stag with S plates I regularly see at the cnr of Grange and Tapleys (at least twice a week), and Mel in her silver Stag on Happy Valley Drive around 6ish.
Edited by 32godzilla
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
