Import feast on the way hm yesterday...
White/Pearl...4door r33 got on the gas to pass me down the expressway just before the turn off to Pt Wakefield.
A sweet looking metallic blue Stag, on Salisbury Hwy at Mawson Lakes intersection. Through a nod ya way but was a tad late.
And a White Stag parked at the Izabeff Centere with a Sau sticker on the rear window...
All in all nice drive hm :)
Edited by Bildo R33 GTS T
hey everyone spotted atleast one person today the bloke who has the little 323 that was at collingrove at the round about near the paralowie shops and also a white series2 33 behind me same area at about 8am this morning :merli:
Paul.
spotted what im guessing is joeyy at D & C carcraft today getting a stocker turbo chucked back on, bad luck with the defect
yeah mate that would of been my car . You might see it back there in afew weeks getting it all back on lol
Drove into the RAAF base behind a nice white Stag this morning - had a bit of a chat with the owner, nice to see some Jap presence out there with Pete's old GTR there as well. And on my way through Aberfoyle Park earlier saw another white Stag with gold rims - exchanged waves as we drove past..... didn't recognize the car though.
spotted a nice 4door 34 with the plates raw-034, sturt road/diagonal road intersection, at about 12.30pm.
blueish green 33 with what looks like dished starcorps with flush fitment at big bucket south road, with a 33 4 door with drift r rims when i got the car cleaned at about 3.15pm.
maroon 33 with tri spoke rims going up main south road hill at about 4.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
