saw a couple 4 door 34's today, one on anzac hwy was blue, and had a chick driving. the other was white, had eye lids and some sticker accross the top of the windshield the front end was low and the ass end was way up in the air. had plates RAW 034 or similar
Spotted a Silver S15 with Aus flags on both sides goin up and down the windy point run then he was followed by a 7 or 8 evo. Also a white 88 model soarer which pulled in to BP. Then seen the Silver 15 again pulled in to a servo in blackwood (with a cop car watching them lights off on the side of the road, hope nothing happened)
Meanwhile down south junk food corner police were everywhere. Sitting at maccas and cops pulled/pulling ppl over near HJ's, also opposite Dominos... Then seen 6 patrol and 2 D cars crusing the area
Wasnt too keen so we bailed :rant:
Seen a Orange 33 with kit always parked infront of that shop at semaphore and a white 32 next to it today, Also spotted a TOUGH black r34 GTR infront of Red Rock eating around 8.40. he looks like Vin diesil =D
Spotted my GTR getting reversed into last night.
f**king mole even laughed about the whole thing in my face.
But I'm the one laughing since she didn't report the crash and the cops fined her with driving without due care and reversing without due care!
But on the plus side, hello new front bar! I needed a new one, anyway.
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
