....and there goes the spotted thread.
spotted a bronze 180sx with a 32 front today.... interesting. around 3pm, out the front of work.
was owned by a mate of mine, used to have plates R32180 or similar, think he sold it but...
This coming from someone that usually has a go at people on here for 'hooning'..... Oh but you had a good reason to 'hoon' i guess... Think twice before having a go at someone else for commenting something like this, or on how tragic it is when someone is killed by a 'hoon', today it could have been you that killed someone..
Who said I "hooned". Were you there? No? I accelerated to 60 faster than he did ... I'm on a bike! No laws broken ... no one killed. One Porsche owner embarrassed ... good result. And I'll continue to have a go at hoons ... so don't worry yourself princess. :D
if he stopped at 60, no laws would have been broken. Rapid acceleration is not a crime.
-D
True.
Cops could probably go me for excessive noise. Thats it. No wheel spin. No wheelie. No speeding. I say I spanked a Porsche and you guys automatically assume I broke laws in the process. Fail. :P
There will be some excuse to say that it was ok though.
Don't need an excuse when no laws were broken. I don't need to go past 60 to prove my point. :P
True.
Well when you stated "I don't normally give in to hoons wanting a race ... but it was an opportunity to put "Mr Compensating" and his Porsche in line. Thats what you call a race? When you state the words 'hoon' and 'race', it usually means you sped upto and beyond the speed limit, why even give the guy satisfacton of a 'race' if your on a bike, didnt think you would win? Also after the first time, why do it again? In the police officers eyes (if one had pulled you over), you did it twice from 2 sets of traffic lights next to a porsche, I recon he'd call that 'hoonish behaviour'..
Nice assumption there. :P
Did I say that I "raced" him? I said I "spanked" him. I said he wanted the race. I just accelerated to 60 quicker than he did is all ... twice. :D
Back on topic ...
I keep spotting the same white R32 going into the city on Glen Osmond Road most mornings as I'm heading out from the city. Anyone here?
:P
Back on topic ...
:P
How do you know he wanted a 'race'? If he wanted a race then you go and accelerate to 60 faster then he did then you gave him what he wanted.. a race.... But really, now im just trying to piss you off, which from what i've seen written around SAU, I dont wanna do that :)
white 33GTR on NE road heading towards the city about 12.30am... didnt get a good look who it was... luke maybe?
oh and then some p plater in an old excel with an exhaust trying to drag me up mcintyre road then onto golden way...
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
