ah you the white 32 i mentioned above..
saw "dare ya" parked out front of tyre power blackwood
Yep...that would be me...seen you stop at the lights waiting to turn left, not sure where the Dark 33 went..seen you behind him though
A sorry looking red R32, having just rear ended another car at Salisbury Hwy, Mawson lakes intersection at 7:40am today.
Didnt look good.... the other car looked ok, dont think the 32 was drivable..... :D:)
Didnt look good.... the other car looked ok, dont think the 32 was drivable..... :P:P
Spotted that also this morning
saw the 'windies' gang last night on the way home from dinner - errm...supra, dareya, mstr34, 2 white 2door 34's, turbotalia, maroon 32, black 32gtr & a few nasty big holdens haha
spotted some joker roll by with a blown gasket... :P
Spotted silver 33 I think it was a gtr had black rims parked out the front of the post office blackwood near the roundabout at 330pm
Edited by r32man09
Spotted Black 33 going south along Portrush Road, had 5 spoke silver rims, was around 3.30ish.
A black 33 GTR going down darlington hill on South Road, looked and sounded stock, had S series plates. About 1ish today.
And MS R33, white 33 going along Kenneth Road, turned left down Flaxmill Road, 4.45pm today..
black 33 with white wheels parked opposite the belair hotel, 8pm
white 32 with black wheels going across the train line about 10 seconds later
'rrr-322' main rd blackwood while i was at fancy burger! about 8.30.
Silver 33, Esplanarde, Moana, stopped in the car park down the bottom of the hill. Blue neons inside the car look awsome :D Had silver 5? spoke rims..
Black 33 on the esplanarde near the onkaparinga mouth, looked fairly stock..
Both tonight about half hour ago..
Spotted a black 4door R31 driving down main north this moring on the way to work. He was reving and swearing in frustration at the lights, swerving between traffic, tailgating, and cutting people off.
Seriously mate, calm down, life is way too short to be stressed! Plus that with all your manovers, I was behind you at every set of lights cursing along in my daily.
Your car sounds pretty tough tho!
spotted 'ICULKIN' twice within 10 mins yesterday arvo round lunch time... first one was on o'sullivan beach rd, lonsdale... then on aldenhoven road...also in lonsdale.... i was the big fella walking along gawking at your sexy ride :(
Spotted Aaaahhhh33 last night on South Road.
Also spotted 2 bogans talking to me last night at like 3am in Hallett Cove. One said his FPV was running 320psi on his "$60,000 turbo"
What are you? From Queen St Smash?
Then the other told me I should get some 20" rims and roll the guards "like his Datto". What a fail.
Edited by CRoNic...
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
