yeah, dave is like this is real life too
haha, dave is funny.. try having him on facebook :P im sure this discussion can be done in the wasteland
was next to, then behind a silver 33 sat morning southern expressway/ south rd/ turning onto states road then i saw black smoke as a maroon 33 pulled into a driveway along there blowing heaps of black smoke out the back :S
  • Like 1
  • Nope 1
haha gold David, gold. I'd love to meet you in person to see how much of a smart arsed tosser you actually are. But I somehow doubt that you present yourself and carry on anything like you do on this forum. Seeing as you blog every useless thing that happens in your life on here that nobody gives a flying fark about, we'll have lots to chat about. What do you deal? Blackjack? or is it Baccarat?
im equally as charming face to face.
dont like what i post? dont read it. its actually a pretty simple proposition. you should be able to figure it out, you might get a little bit of a headache trying to think it through. but i have faith in you.
funny thing though, its my understanding that the wasteland is for exactly that, every useless thing that you feel like saying. i might be wrong. but i doubt it.
i deal a bit of everything. im looking forward to relieving you of some of your money one day and seeing you carry on like every other child that comes to the casino and gets all upset when they lose.
as for my injuries and bad luck. its simply that. bad luck. everyone has a few spells. ill be sure to enjoy some haughty laughter when you have a bad run.
if you want to continue this, take it to pm.
  • Like 2
  • Nope 4
if you want to continue this, take it to pm wasteland.
fixed we all want to see what happens next in the saga that is :D
back to spotted
  • Like 2
Spotted a black 34 4 door leaving my workplace this afternoon on full noise.....sounded VERY good
:thumbsup:
Thats the sound of 304rwk :P
sounds better from the inside I'm sure so I'm sure ul find my passenger seat empty for ya :)
put a brand new street light globe in out the front of SILVERTRACKS house today :P you didnt lie when you said you're a local.......2 mates in a short space of distance haha
plus spotted a familiar looking 32R in a driveway a few streets from me, dark blue, 5 spoke wheels, bit of paint fade :( cant remember the guy's username either (or if he still has the car now)
mycef 3 in edwardstown lately.. its been a while since ive seen it there!
Hey, yeah iv bn driving my N12 for a while coz the cef was broke, but now its back :iluvff:
Where bouts u keep seeing me, What u in?
Edited by MYCEF3
I was working on the GTR out the front and had to duck inside to get something just as your truck pulled up. Had no idea that was you! By the way thanks for the new light :D
On a spotted note, a silver V35 4 door out the front of Japanese Import Spares this afternoon.
    • How fast are you doing the downshift? 4th gear was revised multiple times until 1998 to fix this issue. Synchro clips can fall out, synchros can wear. Most likely you're looking at a new transmission unfortunately. If you need to limp it until then double clutch downshifts into 4th.
    • Sorry I was being harsh there, but am I wrong? You can buy a M340i easily, and there's loads available second hand. A lot more workshops modifying them as well. How about getting parts for them? Don't get me wrong, I'd love a 400R, even a 4cyl (I looked at a few V36s before buying my shitbox BMW). Sadly Infiniti died in Aus and we're stuck with importing them as niche vehicles. Supply and demand
    • Probably straight swap for an R32 GT-R? lol
    • Yes I think we changed out the transmission fluid as I had a leak last year so we changed out the seals also. Need to check.    I should have said just change from 5th to 4th gear … down shift. There’s a grind.    I have a new clutch X clutch … but as I said all the changes in other gears are fine.
    • Change the transmission fluid. I would try Motorcraft XT-M5-QS if you have it in your area for a reasonable price. Also, double check your clutch is fully disengaging. If you are not pushing the clutch pedal to the floor fully for every shift now is the time to start. Make sure the clutch is fully bled. The damper line requires two distinct bleed points to be purged of air or it will not disengage the clutch properly. If either hydraulic cylinders input or output are losing hydraulic pressure in their seals/leaking you can have problems like this. If you've ruled out everything else then the most likely explanation is the synchros are worn and you need to double clutch the shift or rebuild/replace the transmission. The transfer case is discontinued FYI so you may want to rebuild it while you're in there too. If the chain stretches past spec it can do a ton of damage.
