.... driving at the collingrove hillclimb :) great fun!! Also met David with his r33 GTR V-Spec who also entered
That would be my brother-in-law "Red Back" on here .... and he is an SAU:SA Member :) .... I bought him his cool number plates for his birthday a few years back :D
Spotted my mate in his r33 gtst and I driving at the collingrove hillclimb :) great fun!! Also met David with his r33 GTR V-Spec who also entered
Had a great day Scott - good to see you and the crew. :action-smiley-069:
Guys
This went much better than your descriptions of last year.
I was near last in a field of 82 first run was about 11:30
Got six runs in by 3PM
After the second run the process had refined to:
- we were doing burnouts as the car in front was launching up the hill
- cars released when car in front of that was half tgrack at S2
- so a car was being released about every 20 to 30 seconds.
Although the scruteneering and paperwork was slow in the morning (but on time to the program) once up and running it was all good.
I would recommend this to people considering the Come and Try at Collingrove.
Saw a 35R with S series plates parked at a furniture place down south.. Owner i'd say, used to see a 34R parked at the same place..
that sleep center joint? might be ax53b70p25's new car...
33 v spec with plates VSPEC3 also getting the full service at west lakes car wash
Would of been 'Red Back' after the hillclimb yesterday :)
Also as he said above, would definatly recomend it for anyone thinkin about entering! Should involve it in SAU:SA calender
Also spotted a maroon/red 32 GTR with nice dished rims going the other way while i was drivin home from Collingrove between woodside-harndorf area?? Anyone from here?
sounds like Matt in my old 32... he is on here as GTaaaah32 or similar
collingrove is quite fun and id recomend it for everyone to try. you dont really get many runs in, so we just turned it into a burnout comp last time. was much more fun
:laugh:
Best. Starlet was a pretty solid performer...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
