spotted dion passing the cavan steak van about 1 this arvo
and a yellow stagea heading northbound in the same area about 20mins later
was incognito in the carpark munging on a steak sanga :P man i forgot how good that place is
Saw yellow stagea with black bonnet behind the geps cross drivein about 40min ago. Flashed your lights at me but i dont know if you seen me wave back.
Spotted your wave buddy,:thumbsup: was trying to keep my choc milk from falling in my lap after flashing my lights
Spotted a silver R35 GTR parking up at Rosewater Foodland yesterday night about 8:30PM
and an R31 2 door thingy with some guys hanging it in the woolies carpark along Sir Donald Bradman Drive about 2:30AM last night
Spotted a white V35 with gold wheels on o'connell street this morning, a white 32 gtst at boostwork and Ruby on his way home in the black stag. I flashed you roo but you were paying too much attention to the road :spank:
lol, flashing people again hey matty :P
spotted brad's tommykiara parked out front of munro's caravan yard this morning, and a dark blue 32 gtr with p plates down on morphett road by immanuel college around 4 this arvo
spotted brad's Tommy Kaira parked out front of munro's caravan yard this morning, and a dark blue 32 gtr with p plates down on morphett road by immanuel college around 4 this arvo
Yeah I was just showing John my car. Unfortunately there was no R35 around to look at.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
