spotted DC GTST turning off Brighton road onto the road that runs alongside the rail line towards Brighton station a bit after lunch today
Yeah, that was us causing all the havoc :P i was on the other side of the line on the back of the winch truck haha
Haha did notice you guys and was trying to look back in the mirror to see what you guys were doing :P Also noticed the girls there, one wasn't half bad ;) Couldn't turn right on the street earlier as they were doing some surveying or the likes... what time did you guys finish? Think the truck was still there when I got home around 5:30pm?
Haha yeah, we've got Noone's doing traffic control for us, there were heaps of people tooting during the day (and its much of a relief having some good eye candy to look after traffic management for us haha)
We finished yesterday at 3:30 (Noone's backfilled the hole afterwards, so they mighta finished late). Back there again today, finished at 4:30 O.o
(as for what we're doing, undergrounding all the overhead mains over rail crossings :P prick of a job, but someones gotta do it haha)
That explains all that work.... work's work which is the main thing aye :) I wouldn't complain with those lollipop controllers :P
cheers mate, I wasn't on Hampstead road for long though, you must have sharp eyes ;)
-D
U were just turning out of a side street...always have my eyes open for imports in the city, makes peak hour more enjoyable :)
Heh that'd be right. Turned out of one sidestreet, into the middle lane and then right turned into yet another sidestreet. Main roads SUCK during peak hour.
-D
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
