Back on topic ....
Anyone spotted any cars of note tonight?
Seen Grim's 260 tonight. He saw my RS4 ... together with its rushed paint job on the Dolphin kit :ermm:
  heslo said:
How goes my 25? You put her in the car yet or she just sitting there? :laugh:
i dont know how does she go? you were the last to drive her :banana: project sil25 has gone.. moving out soon so sold up :D
rad everyone wants my box and im not even a girl :ermm:
Edited by shy_s6
Spotted Adelaide post whoring:
Joined Total Member Posts Posts Today % of today's posts
Madaz 11th September, 2004 8,174 49 4.09%
InH3aven32 24th April, 2008 249 32 2.67%
m3gtr 5th December, 2006 3,274 23 1.92%
JMP 82 28th July, 2003 3,408 23 1.92%
R31Nismoid 3rd August, 2002 20,568 23 1.92%
rad32 17th January, 2005 1,639 22 1.83%
heslo 27th June, 2005 2,306 21 1.75%
ctjet 5th September, 2005 17,263 18 1.50%
JAS-25T 1st December, 2003 7,297 13 1.08%
DSTROY 17th May, 2008 445 13 1.08%
RubyRS4 11th March, 2008 1,424 12 1.00%
your all so worried about post whores how bout you all get off your asses and do something for the community, thats hardly a relevant spotted post so maybe your a whore too scott
that aside took a photo of the burnt out 180sx on my way home from church
Spotted Matty in the Red SAU commodore yesterday, would've waved but was in the mrs' BMW.
Cruising with the family down waterloo cnr road behind a low R34 GTR in bayside blue. Was trying to explain to my parents why it's 40 grand more than my car lol. They didn't understand, i got the mum comment "oh Damien i think yours looks better", lol, told her id give my left nut to get a GTR.
so was she semi relieved as u wouldnt be having a kid anytime soon?? ahha
    • Don't "upload" the pictures. Just copy the picture direct from somewhere (I usually am pasting screenshots or something else that I have on the clipboard as an image, not as a file" and just paste it direct into the post editor. Just like you were pasting it into a Word doc or something. You can't damage something if you lift it where you are supposed to. If you look carefully at the correct jacking points, you will see that they are reinforced right there. And nowhere else. That is where the "foot" of the factory jack is supposed to sit. That's why you need rubber pads with slots. 10mm might not be deep enough. Note also that the slots are not required if the pinchweld has already been slammed flat. You could just lift it at the correct spot with a flat pad, because the damage is already done. No point in making worse though, if it is recoverable. IF. Yes, that's called a chassis rail. You can lift carefully on these, if you spread the load. A decent block of wood is good. But keep in mind what I said before. Any time you start doing this sort of thing, you are off the normal path and into "be bloody careful", because it is obviously not stable. Dumb. The refinforcement is already there. See above.
    • yeah looks like they've been lifted there previously but with solid not slitted rubber blocks. I'd just bend them back (combination of vice grips or hammer with some sort of drift, then hit the area with underbody protection paint. As for the siderails, I'd call those chassis rails and that is exactly what I meant about being careful with the balance point. You can probably lift off them at the point where the 2 pieces overlap, but you need to be careful with the forward balance of the car if you do when the engine is in....sills are a better choice. I guess you could weld some reinforcement in the sill area near the jacking points but it shouldn't be necessary if you use blocks with a slit. If you do want to reinforce it I'd use square section equal or taller than the seam and then just use flat rubber blocks for lifting
    • driver side sidemember and jacking point (looks the worst by far) driver side rear jack point passenger side sidemember and jack point passenger side rear jack point   Ignore my mug on the last photo. Turns out I was just too stupid to properly use the forum's attachment feature previously
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
