no idea only saw the arse end of it was prob around 1.30ish i rekon
Was driving on grange around. 1245.
dont tell me I was actually 'spotted' for once . damn.
Also. saw a yellow 34 boost down nth east road near ttp around 4pm. and a R31 with front mount near by
black 32 gtr plates R32GTR going past the brewery this morning,
had white impuls, looked clean!
Unless someone has stolen my plates R32GTR (goes and checks ,no , there still there) I think you must have the rego plates wrong. :D
If you said silver 32 gtr plates R32GTR going past the brewery etc (checks car still there) then I would of been worried . ;)
O WELL . :(
Spotted red stagea the other day on main north . Nice and clean. Think it was tuesday.
Also spotted a silver stagea around the corner from me .RSfour with p plates. Think the owner might of had a purple 180 before.
Seems to me that they are getting more common than skylines :D
They might have to start up their own web site stageasaustralia.com LOL
Unless someone has stolen my plates R32GTR (goes and checks ,no , there still there) I think you must have the rego plates wrong. :P
If you said silver 32 gtr plates R32GTR going past the brewery etc (checks car still there) then I would of been worried . :P
O WELL . :)
maybe it was silver :P
my memory is pretty bad lol,
nice GTR man!
spotted a White R33 with what looked like blue trim rings on the rim edges on south road headn to Aldinga last night. gave a wave, got a wave, anyone here?
spotted a grey R33 in christies last night, think they person must live there I see it all the time parked.
Who has the Charcoal grey R34 4DR near the Emu ? anyone here? the car looks familiar ?
last night/this morning about 3am white R33 and grey 32 4 door passed work on north east road at the same time, slowed down for people on the road then boosted down towards the city. lucky the cops near by didnt bother to follow.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
