Damn... Would've been me...
So one of my brake lights is out eh?
Yeah I thought it was you but I wanted some one to own up before i posted up....
How come each time I see you driving and you claim the spot... your weaving traffic and tailgating dude? Not a personal attack or anything, but I dont want someone having a got at me for someone elses bad driving at another time cos my car looks similar.
let me guess running late for work again? >_< lol
maybe keep the racerboy driving for your way down greenhill in the hills section on ur way down from uradila...
few out today taking advantage on the cooler weather, almost needed a jumper today.
black R34 going down ne road and then onto mcIntyre about 4.30pm. might have been the same one from the other night.
grey or black (cant remember) R32 on the golden way about 5.30pm, followed it down mcintyre to main north. then we pulled up to the lights at the road that goes through mawson lakes to sailsbury highway where there was a white r33 series two.
another R33 on military road near tennyson beach about 7.45pm
that was me and my old man on the way to work
mine is the one with the nismo LM GT4's
were you in the black 33?
Spotted two silver R33 GTR's cruising down Grand Junction road, this morning at about 7:45. One of which had black Nismo wheels...
Its funny. I was running late for work again, ended up getting to work 2mins late.
Which is even more annoying because I would've been fine had i not been caught behind people doing 40kms down Greenhill Rd.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
