how about we all start spotting new GTR's for Pete :P ive already emailed my submission
unfortunately timing is wrong :)
I've found two..
http://cgi.ebay.com.au/1993-Nissan-Skyline...7QQcmdZViewItem
http://www.skylinesaustralia.com/forums/R3...ec-t254285.html
And pete, dont be afraid of the vspec 1. the only thing the vspec2 has different is wider tyres ;)
-D
Last night spotted DStroy, matt31, and a couple of others I recognised but couldn't name at west terrace BP. Then saw typevu turning onto east terrace out of rundle St. On my way home I spotted and briefly cruised with once again DStroy, enr-34, and two other nice 'lines up the freeway till they turned off. Make the Stag look pretty sad really.
thought the stag with the polished 32 wheels was familiar :P
I would have come over and said hi but I didn't know anyone and my missus was tired (rolls eyes) lol. Was glad to get a bit of a cruise with the guys up the freeway though. Topped the night off.
The polished wheels came off my 32 (to be track car). The 32 now copped the poxy original rims ;)
:) Yeah I was parked behind you at the Bushfire cruise meet. BTW that patrol is mint, I see so many of them at work, it's nice to see one in OK condition let alone better than showroom.
spotted a half a dozen times today, the Grey R32 GTR? doesnt look like a GTR but had the emblem on it, with the weirdest front bar , all holes
and rego Godzilla. he was cruising up and down commercial rd. pulled into maccas seaford to see who it was who waved at him
have to say that car is butt ugly but the girl in the pass seat was cute..lol
and the dude is arrogant as hell, trying to show off..lol
spotted a white R34 with black wheels seaford mobil
Edited by sapphiregraphics
spotted on north tce a buggati oldschool broken down, we gave the dude a push in our drunken state.
kinda looked like this only purple
poor newly weds in the back had to roll in a getz whereeva they were heading from there :P
also spotted silva r33 gtr on main north around 6pm
Edited by Inline 6
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
