OMG!!! I totally spotted 2...yes 2 skylines today!!! A real nice white 33 and a white 32!!! Woooo, got me all excited. (PS: Im in Scotland atm for those of you that dont know, theyre kind of a rare (rear haha) delacasy lol)
Lol dan didnt see u? posing? Nah, taking a scenic shortcut :laugh:
i was posing on foot suprisingly this does not draw as much attention as you would think maybe ill go back to the car thing or get them to put my super bright green cast back on
i was a lil bit past the corner you turned on heading for uni and yea i noticed ya didnt see me. good ta see you were concentrating on the road ahead not your mobile phone :bunny:
Edited by gzilla
drove next to a white r33 gtst with chromies along main north rd from mcintyre rd around 11pm...
well until we stopped at the lights....
his turbo, mine not...i did alright though..wasnt too embarrassed :P
hey guys and gals i was down adelaide this week. and spotted hot blonde chick in a silver r33 with gold rims, white r33 big chrome rims and a sick black r32 with the loudest sounding blow off valve ive heard. spotted heaps more but havn,t added them.
cheers... michael. p.s anyone here from pt pirie s.a, as dans the man with the drift skills. :D
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
