Spotted ruby around 6ish on south road up near regency park in his 33
I was towing a grey r32 gtst behind my ford.
Ah yes, I noticed all the imports on trailers going the other way :P
:P
Spotted a black 33 with black rims about half hour ago at south road and forget the other street, heading south.. Had S series plates and a chick driving.
Also forgot to mention yesterday i saw a old white 31 getting very sideways coming off the expressway onto marion road, so sideways he almost spun round, infront of other vehicles.... Dipstick :P
hmmm got me farked. :P id be wondering what the hell he was doin if he broke that clutch. prob something simple. i had the top of the clutch peddle snap off before and the cluch just stayed on the floor. would have just driven it home myself. car can be driven with no clutch and no crunching gear if you know how to properly.
You are exactly right Carl all i was doing was driving through Hungry Jacks drive through and CRACK lol. Clutch pedal straight to the floor. How do u drive it with no clutch and no crunching???
Big thanks to MYCEF3 (Ryan) and Josh in his S15 for coming to rescue me. LOL. Didnt even have to ask for their help and they came. Both top blokes. :P
its called getting in harmony between you and your car. That car can and has been driven with no clutch from 1st to 5th. Just use thr right revs and feel the car and can be done. Just have to stop it at all the lights and start it to take off
do u have to have it in gear and then start it in gear or can you get it in gear with no clutch from a stand still.
ring me bro. ill explain it and you might be able to shed more light on the situation for me.
Spotted "SPY034" at Sir Donald brad & James Congdon Intersection today
Spotted (didnt get the plates) Purple Black 34 GTR at Windies
Spotted Purple Black 33 GTR coming up behind me on the way up to Windies, trying to overtake at one point lol.... :happy:
is there a private praccy tommorow?
would love to come up and watch the GTR's if spectators are allowed.
Nah no spectators allowed I am afraid .... but I guess it is a free country, and if the gates are just sitting there open .... *whistling* :happy:
does anyone on here own a silver 260rs thats dumped with plates '260rs'? saw it just outside burnside.
also saw a silver r35 gtr in a driveway on lower north east rd somewhere. (wont give address details :happy:)
saw heaps of stags today. a silver stag racing a blue rx3 near the vic down south :s
heaps more but nothing that stood out to much.
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
