spotted a black 32 with HID's on blacks road, going through oakridge road roundabout, at about 2am friday night, and spotted about 4 32's at turbo tune friday
That was me on my way home, i spotted your 31 :bunny:
Spotted a yellow 34 with a spoiler as high as the roof needing a good clean, a silver 34 gtt 4 door with a car sales sticker on it, a maroon 32 gtst with a kit and a very clean white s2 33 all at Hackham Woollies just before.
Yeah seen that quite abit.... Not a fan of the gay nismo wing :)
Spotted a few imports at windys then around on roads till hungrys mitcham!
Who owns the black aristo for sale (giving the car a bit last nite) Car is mint, nice n quick as well!
And the silver 33 in front of the pack last nite???
Also had a good chat at hungrys hallet cove wiv the owner of the silver cefy... PM ur number mate wanna know about this cefy cruise!?!
Edited by MYCEF3
seen a couple nice/clean 33 the other day, one was driving down womma road, seemed to be a s2. and the other was parked outside a house near munno para shops.
oh and i seen another on that same day parked down peachy road. i think all on sunday, cant remember
Yeah the one near Muno Para has a huge dent on the LH rear 1/4, see it quite often as im around that area too
spotted a r33, rego (black and silver plate) DWN or something like that ....speeding thru a construction site at least 20k over the posted limit along with a red and black VE Commo SS
your so lucky the cops werent setup in that area like normal.... if your on here your giving us a bad name, in the end you ended up behind me at the traffic lights anyway
I'm not impressed by your speeding by me :( to show off, and by the way your car needs new passenger side rear shockers its all over the road when you hit the bumps
spotted a porn R34 GTR vspec 2 near expressway , Black one ....might be that chick jesse ..lol . :P
and a few nice R31 4drs,, XXXI rego both very nice
and another one drifting around a round about in christie downs , totally thrashed one .....P plater...moron
Edited by sapphiregraphics
Spotted a dark coloured possible black 32 GTSt getting it out of shape out of a side street onto Tapley Hill Rd Seaton this morning at around 6.45am :(
Also spotted the police on the Hanson Rd exit (onto Salisbury Hwy extention) with radar getting oncoming traffic in an umarked silver VE
Spotted Krishy this arvo at Golden Grove KFC, good to catch up with ya matey!
Yeah it was good to see you and your mate Jugz as well
i havnt been up there in ages so decided to venture on that side of town yo
Spotted me being pulled over by full undercover officers in casual clothing and all Sunday night after a hills run but when I was down near my joint, coming down Cheltnam pde. All the officer said to me was 'The car yours mate?' 'yes' 'Registered in your name?' 'yes' 'Can I see your drivers license' then walked back to his car, came back gave me my license told me to keep obaying road traffic laws and took off :D
Still havn't had any issues with any cops in my car yet.
Edited by Weezy
Good to see you were all ok! Would have hated seeing you with a defect after such a nice hillsy
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
