spotted a black stag coming from blacks road roundabout onto oakridge road while i was on my run, gave a thumbs up to him plates starting with XTS at 8.30pm, and another black stag coming down oakridge road about a minute later, custom plates, nice exhaust sound
I just want to say that my mum tells me of Skylines that she spots whilst driving around. She is pretty good at picking the GTRs and knows the difference in shape of the 32s & 33s by referring to them as like my car (R32 GTR) or Chris' car (he has a R33 GTR that's been at my house for a while). Kudos Mum - you are way cool. :cool:
reckon u can ask her if she wants to swap my turbos over? Im well unco at mechanical stuff yo
spotted a douchebag in a red gemini with big wheels try to egg me into dragging him on anzac highway
so i granny shifted and pretended there was a cop behind me and he fangs it (slowly) to 70 and backs off
buddy, I'm not so stupid as to drag on anzacs, and a gtr vs a gemi? nigga please...
-D
Edited by Dohmar
spotted a light blue metallic /vertex kit r32 with P's on south road, got a look over . no wave
pretty sure that r31 lonsdale drifter is more of a off white car and yep he does flog it around the south a lot, heard him cain it down the road yesterday again. my ex keeps getting pulled over in her White r31 for rego checks and to check to see if its stolen(3 times now in noarlunga area) , cause hers looks similar to it but with black window trim. amazed she hasnt been defected, just asked to replace her windshield since it was cracked in drivers vision but never a ticket or defect....lucky bugger
I just want to say that my mum tells me of Skylines that she spots whilst driving around. She is pretty good at picking the GTRs and knows the difference in shape of the 32s & 33s by referring to them as like my car (R32 GTR) or Chris' car (he has a R33 GTR that's been at my house for a while). Kudos Mum - you are way cool. :D
I can do one better than that..... my mum owns a 33GTST! :P
Is it a silver 4 door? lol its a long shot but I see a mature age woman driving one around fairly often and I know I live kinda near you guys.
close but no cigar...lol.
Its a silver 2 door m-spec!
Mum doesnt live near me, but i know the silver one you mean, i dont think they are on sau, ive given the wave a couple times with no response!
S1 4 door NA in the golden grove area? If so I used to see that one daily
I think that is Guy's car your talking about steve....
on another note spotted a gun metal grey 31 4 door getting all crossed up in Victor Harbor today....4 bogans.....if only my car had flashing lights arrg
Spotted a black 33 driving along me 20 mins ago on pt Wakefield road with a big sticker on the rear window saying EP Performance, Also spotted at 3 a red 33 driving behind me on Walkeys road then turning left onto Wright road and did a u turn.
Spotted a SIK 034 4 door pulled over by an undercover in a side street off Sturt Rd around 4.30p - bugger mate, hope it wasn't anything too bad. Then a black 32 GTR at the Beach Rd roundabout heading east, then 2 mins later a red Stag (plates XSL-???) that looked like it had just done a rally heading west on Beach Rd.
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
