Spotted black r33 around 1ish near ttp, dono what the road was called, has same led rear lights like mine and was a blonde female driver. Also spotted afew times a silver r34 and a white Stagea with rear windows tinted very dark at the same house in Walkley Heights.
spotted a gunmetal grey 32 parked next to a silver chaser at gepps cross kartmania this arvo at about 2.30, and a red 33 with a kit, dished rims, in fluro top, on south road at about 3.45 near the railway crossing, i was staring at it in a blue falcon. hate falcons so much...ford in general suck..
spotted silver stockish stag with a girl driving it at the intersection of conington cres and south road, morphett vale this arvo...i smiled...she drove on :( ... also in the same intersection a clean burgundy 33 with chrome rims....
vt commo with metallic lime green body kit parts,, SWEEEEEEEET!!!!!!NOT
This was parked across the road from my house all day today. I walked past it shaking my head thinking that the owner would actually believe that his/her car looks good...
Pretty sure I spotted DAYZ's yellow Stagea turning right from South Road to go down Chandlers Hill Road on Tuesday about 3:15pm.
Edited by writeoff
Spotted a nice blue R34 GTT (wingless) with what looked like BBS Wheels on Port River Express Way this morning heading west. Looked pretty tough for a wingless...
Also spotted a white VX commo on Tapley Hill Rd Seaton with the LUMINA badge reversed so that it read AMIMUL with chev badges.... I lol literally!
Spotted at around 8.40 this morning a Pink r33 with custom plates, not sure what it said but had gold writing on black background. female driver =], also spotted up ahead was a black 33.
Edited by kb-r33
Spotted about 20 minutes ago a pearl white R33 4 door at the end of Hampstead road at the same traffic lights I was at. Then like 30 seconds later at the lights of NE Road/Galway avenue, 3 lanes, 3 skylines - all in order. My R32, the pearl white R33 and a midnight blue R34 4 door.
that would have been belinda, her plates are NIZMO
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
