Spotted Dave's S14 driving along Main North Rd crossing Grand Junction heading South at approximately 10:50am - noticed a red S14 with shiny wheels and the parrot hanging off the rear confirmed it was him(who else with the same car in Adelaide would have one? lol).
yeah they pulled in to run plates , HOW LAME !
then they thought they had something cause my mates car is defected but hello clearance note haha
lol clearance notes are awesome, ultimate slap in the face of the officer.
Spotted a red R34 GT-T heading north around 5pm today on Main North Rd near Montague followed closely by a yellow Stag with S plates and a big front mount. Then a clean black R33 GTS-T S2 further towards the city - plates WIR-xxx.
spotted a silver stagea plates xpt683 about 4ish on south rd extension then turn towards mawson lakes. women driver too.
tough stance with some nice dished wheels.
i was in the frontera that was in front of you. couldnt help keep looking back at the tough stance.
Spotted
RRS-260 South Road at 7.30am
White 33 with no front bumper, chick driver Hampstead Road about 8.10am
White 33 plates "ko 33" South Road 3.10pm
GTR 091 South Road at 4.10pm
68IOU1 parked im suspecting at his or her house
Edited by skwiz
spotted a clean R34 coupe at carline mufflers lonsdale earlier
he got a full exhaust system installed onto otherwise stock GT-T
told him to sign up here
had my magnaflow centre resonator installed to drop drone noise to a minimum
its a work in progress lol =]
spotted a grey r34 without the wing.. going around a roundabout in gawler near the post office. about 4pm
If it had chrome rims, it would have been Penny (ontheranch)
Also spotted a Grey R33 with Starcorp Impuls - or whatever theyre called... on Gouger Street City, just before midday. Sounded nice.
silver stagea at woollies on kesters rd (para hills i think it is). Saw you driving out as I was walking to my stagea. Had a trolley load of individual items because i refuse to pay for shopping bags (just moved from brisbane so i'm still not in the habit of taking the "green bags" along).
    • If you do go with drain back, make sure everything is foam or wool filled so it actually does something, and ensure there is a screen somewhere in the drain to catch anything that comes loose from the packing. I don't drain back
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
