[SA Cars Spotted Thread #3]
N/A®
spotted a black series 2 33 with i think a gtr wing at subway bp darlington abot 1pm today,
spotted a red s14 with a front mount on o sullivans beach road about 5 thirty with a female driver
and spotted a white one too on brodie road just after..
Haha. Kinda like seeing fat chicks wear belly tops, Why would you? Who told you that you look good enough to leave the house ahaha.
Quoted for Realness
Saw vspec-34 on Adam road turning right onto Port road, and then 5 minutes later some cockbite in a black 32 fanging it around the corner from port road onto adam road, dropping a few loud cannon shots along the way
noob.
-D
had another silver 33 series 2 behind me on belair rd mtcham, also saw a lotus of some kind wit rego "PWNED" :P then saw 2 32s heading through blackwood, one maroon and one with rego "S UNIT" sounded tough
The owner of that Lotus is the organizer of INLAN, that is held in the Blackwood Bapdist church Rec Hall.
Sorry, i don't know. Haven't been to INLAN in ages, and i haven't really spoken to him. I am trying to find his blog, i found it awhile ago and had some good pics, but i can only find his twitter and facespace stuff...both to which i don't have accounts.
*EDIT* Found :D
Edited by Aberax
forgot spotted what appeared to be sleds old ride at mt lofty fri night. how you could sell such a fine automobil is beyond me
I should go and say g'day to the current owner, I see it on a weekly basis at work.
Good to see it getting regular use, but if it was me I'd probably only take it to work when it isn't pissing down and windy as hell - the place is a muddy/dusty shit hole with all the development occuring at the moment.
Spotted an R33 parked on military road with blue flames up the side, body kit, and if everything else wasn't bad enough some 20" +60 rims aha,
Looked really really bad, I find myself asking.. Why would you? Haha. Kinda like seeing fat chicks wear belly tops, Why would you? Who told you that you look good enough to leave the house ahaha.
Was that the celtic flame looking thing on a silver 33? pretty sure I saw that on my way home from the physio on military rd. Almost hit a parked car from laughing lol
i Also saw Vspec 34 going across Port Rd around 10 to 5, Really fine automobile.....
And i saw a white 33 with MASSIVE blue flames down the side(HAHAH) parked on Brooker Tce near Richmond rd........large dumptruck was leaving the servo and almost hit it.
    • Thanks. I agree, looking at those plugs in conjunction with good compression/leak down tests I'm not too certain its ring related anymore.  I have a Swagelok ball valve on the drain and tubed it lower down to the left side of car to easily dump it into a container. I do not drain back into the sump. I've never had to drain it though as there's never been any oil in it.
    • Best bang for buck at the moment would be a 86/brz. Good chassis,  plenty of aftermarket support and parts everywhere.   I just picked one up with some quality gear and it drives better than my old 180sx.    Also depending on what your doing and budget.  An a90 supra is my pick if want to spend more. Great chassis, solid motor, gearbox is good. Development potential is crazy. They are doing well in prod sport and time attack. All the old jdm stuff needs alot of work as most of it all bent and over priced.
    • It's basically the same platform, hence why everything bolts to everything else Kelford camshafts were recommended by Mania after they asked me what I want the car for, I said "I'll thrash it around daily and maybe take it to the track for fun" 🤣 Factory NC 2.0L cam specs: - Adv. Dur. 256 /256 - Dur @ .050 205 /190 - Lift 9.42mm/8.13mm So, as I know nothing about cam specs, all I can say is the numbers are different and it should get a little bit of lope....🤣
    • Depends on how extreme, however if you look at SMSP, they're all dominated by Hondas and M cars on amateur/street car events.
    • Without better pictures, it won't be possible for anyone to work it out further than we have.   Start measuring, EVERYTHING. Thickness of flywheel, and all around it. You want to know is if everything parallel. If from the face of the pressure plate (that bolts to the flywheel) if it is parallel to the pressure plate face, then something is NOT parallel or equal elsewhere. Or you've bent the shit out of the fingers in the pressure plate.
