[SA Cars Spotted Thread #3]
N/A®
well.
69UOM1 proved how hektic he is again today, by STALKING my girlfriend Jess and her friend who were walking, for 2 blocks, doing a U-turn, just so he could pull up on the side of the road next to them, whistle at them, do a burnout, and slide it all the way up the road.
Dude, if you're on here, I only have one thing to say:
You're a F**kwit.
Hope he writes the car off being a douche as always. We wont have to cringe every time we see it, and He'll get what he deserves.
Win win situation the way I see it.
http://adelaide.gumtree.com.au/c-Cars-Vehi...QAdIdZ166299455
:bunny:
saw a yellow 34 coup going down towards junk food corner morphett vale.
had a massive hks sticker down the side with the whole wolf thing onit too plus some other stickers, drift r's and i think ACT plates.
loose the sticers dude and it'll be sweet
Edited by Import S13
Spotted Sled last night at Dinner with his wife and kids. >_<
good to see you again Shaun.......& Hostile & Ryan (ISC) & Geoff (EHP) & RBWARE (with wife & daughter).
Also spotted a Patrol truck briefly on Brett West's Mainline rollers getting its exhaust pipe cleared out....wasn't yours was it Matty?
Spotted a silver 33 last night at woodville hotel in bottleshop next to mine, half tint, looked like a home job, revving his engine like i was impressed :)
This morning on way home spotted a black series 1 33 near womens & childrens hospital, looked like it had 350z wheels.
Then a white 33 with drift lip on king william
Grey 32 GTR on corner of west tce and anzac hwy, big defect label, unlucky
well.
You're a F**kwit.
When I was working at sinergy that filthy leb jockey brought his car in there.
Cvnt really is a 'hecktik' sh1tcvnt...
I hope you deleiver to him what is in order or he cops some sort of other bad karma.
Spotted a black 33 yesterday, seen it a fair few times around christies beach area, sounds pretty tough.. Had S series plates.
Also had a silver S15 come past my house the other day and toot at me? Anyone on here.. Always going past up elizabeth road..
    • Hurry while stocks last! 🤣 13% points redemption on this $6000 Mont Blanc "James Dean" ballpoint pen at Yodobashi Camera in Umeda, Osaka
    • It's not that at all....I just love the R chassis too much to keep racing it! Absolutely impossible to fix the damn thing if I bend it.... That last off I had (when I neglected to do what Kel said), we removed a gum tree with the side of the boot....needed a new rear quarter, boot lid, floor straighten, rear bar, front bar, both front guards, radiator, bov return and I still haven't got it back for a proper alignment to check it is actually straight again). There are just too many ways in tarmac rally to do significant damage to a car that you can't really get parts for.
    • Now I'd said earlier I'd checked the fuses, and per @Stick180's suggestion I checked them all again. The check was to use the multimeter in continuity mode on the top of each fuse where the little metal tabs are available for that purpose. All good....except that very "A/T Control" fuse was actually blown when I pulled it out and looked at it. Put it back in, tested it again, there is continuity to both sides even though the fuse is blown. I'll need someone smarter than me, but my suspicion is that I was getting a circuit through a power supply, through an incandescent globe somewhere, to earth, to the shorted wire and back to the other side of the fuse, making it look like the fuse was OK when it wasn't....please anyone that understands this f**kery explain it to me. Bottom line....that suspicious purple/white wire, in an undamaged factory loom, that goes to the the wrong place in the fuse box has a dead short to earth, confirmed from both ends.  How a single wire in a factory loom can be shorted, especially the best protected loom in the whole car (underneath the top of the dash) is going to keep me awake at night because surely whatever caused the damage has (or will) damaged other wires in that loom too. So, to finish this long and sad story....cut the purple/white wire where it exits the fuse box, ran a new wire from there to the ECU loom pin 31, fired it up and drove happily into the sunset. Only 4 days of head scratching and peering into footwells to get me there. Another collection of wire removed (in addition to the earlier photo) and a bunch of 10a fuses that gave their lives for the trouble shooting....thank you for their service.  And, since the car was in the shed I resealed the cam cover (first time I've ever had a new seal leak on an RB, but the Stagea is that kind of lucky), and I put in the boost doc cam splash plates to try and turn down the blow by a bit while I was there. Which, was all good because it also let me find the slow coolant leak, turns out it was from the turbo water supply which I nipped up again (the banjo bolt got new washers, and I tightened the hose end and hose to banjo fitting while I was there)
    • So, as it turns out, a new wire was the answer I went for, but getting there was not straightforward... Firstly, I'd been told before by shops that had worked on the car that it had some weird factory wiring, and I can now confirm that is true in at least a couple of places. For example....that very purple/white wire that provides IGN power to ECU pin 31.....I traced it out of the ECU loom into a connector high on the nav's A pillar under the dash, where it headed up and out of site across the dash, then back down at driver's A pillar. After trying about 8 different relays I found it coming into the back of the fuse box, and confirmed it was the same wire with a multimeter* (more to follow on that.... So, which fuse is the ECU IGN power connected to in my car?  Very top right, labelled IGN (good), 10A (good), Auto Trans Control (WTF?). It's not impossible it has been f**ked with before, but if so someone removed the pins from the back of the fuse box and moved it somewhere else, noting an AT control fuse would be functionally useless as the car was auto converted to manual long ago. It is not simply a wire cut and joined to the wrong place, both ends of the wire are the same colour just one is in the wrong location (you can see there is an IGN Engine Control fuse in the bottom row 4th from the right. Note, that is the fuse box sticker from my actual car, so either I have the wrong coin holder sticker, someone f**ked with it post factory, or factory sticker does not match the wiring.....whichever option it is just plain weird. Undermining the likelihood of someone having gone to that trouble to move a power feed when everything else in the loom had already been butchered....the fuse next to it IGN 7.5a ABS doesn't even have a wire running to it....so no idea where that fuse is on this car. All strange. But not the problem with my ECU power.
    • New tank clean paint and install complete 🤙
