no front bar, i was at the lights and i saw him then he did a u turn and chaised after me, pulled up next to me and sounded his siren and told me when the lights go green to pull over the lights stayed red and then he sounded his siren and said "i have another job get you bar fixed kellie" lol
also boys and girls officer neil is in a unmarked car now
oh ok so your going to take locky to school pick him up and take me to work and pick me up as well??????????
dont judge me
lol, it's because you are going to be sucking up small children with the front mount :blink:
also spotted a white 32 going through marion road/daws road intersection, around 5.30pm.
Spotted a Midnight Purple R33 GTR on the Southern Expressway...then the guy followed me home - another GTR stalker :blink:
He was a nice guy who had just purchased his GTR and brought it over from Melbourne and was after some accurate information after speaking to 'Toy Cars'. I steered him to this site.
Was his name Jarrod by any chance sounds like I guy I know??...
I said to him if you ever need a hand with info ask me or sign up to SAU.... Decided to stalk instead haha
dont judge me
Right, so a genuine comment/question was met with hostility? Cheers.
Just because I have to go to work doesn't mean I can get away with the excuse of having something like bald tires. All I said was you should count yourself lucky, overreact much?
what ever luke bald tyres are not the same as no front bar, bald tyres cause accidents!
if all you said was count yourself lucky i would have agreed with you but saying you dont even know why im driving is just plan stupid, being nasty much?
How am I being nasty? Driving with no front bar and hitting a pedestrian at low speeds can seriously cut up their legs or other body parts. Whatever, think what you like
yes exactly and thats why there is layeres of tape on it so its not sharp !!!!!!!
as good as tape might seem it wont stop majority of the damage :blink:
if you want some crumby nismo front bar just so theres something on there you can have the one i have spare just so you dont get defected or hassled
So can hitting someone with a bull bar, FG or CF front panels which crack and or shatter on impact (either high or low speed), exposed bonnet pins or even a number plate can slice through flesh quickly even at low speeds.
i seen your car today, you actually happen to work in the same complex as my missus,
your car stands out like dogs balls with no bar, sticky tape or not.
im surprised you havent been done yet tbh
PS summoner, fkn lol!!
this is why i have tapped razor baldes to the front of my car to cut through the wind and bogans :blink:
Exposed bonnet pins do not meet ADRs specifically because the damage they can do to a pedestrian in an accident. Not sure what the laws are on bullbars or FG/CF panels - but CF/FG bonnets have to meet ADRs otherwise they're illegal too.
so thats why i got a white sticker that cost me $25.50...
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
