Spotted Madcat, Mitch and his mate up at Windies tonight. Nice to meet you Mitch and friend. Not many ppl out and about. Also spotted DRAKO5 doing a few runs up and down the hill. LOL.
duuu haaaiiii. hahaha yer that was me. nice meeting you too dude!
spotted a yellow 33 GTR on brighton road about 35 mins ago complete with negative camber on the back and positive camber on the front o.O
haha bloody victorians with their whack alignments n shizz, car looked clean tho.... :)
spotted a black 34 R on north terrace out front of work at about 3am, lumpiest idle ive ever heard, seemed to take a fair bit of effort to keep on the straight and narrow under power.
spotted a silver r33 getting defected on pultney st at ~11:10pm
that musta sucked
spotted that as well, probably for the gay chromies :D
also spotted a yellow 33R being pulled over by STAR group on anzacs up near the ETSA building. suspect the same thing would probably have happened to hom
lol ^^
abe at vilis yesterday evening
tom at windys then talia around goodwood and a few other 33s white and maroon one i think near maccas cross rd around midnight
Edited by stolen-gtr
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
