spotted one of the cleanest stags ive seen for a while this arvo on the way home from stansbury... black with chromie 5 spokers... rims really suited the car imo... turning off of the pt river gawler expressway thingo onto pt wakefield rd....
Spotted quite a few today whilst out on a Sunday drive - nice white 260RS Stagea on cnr of Glynburn Rd and Payneham Rd, spoke to the driver - hi if you're on here. Later on saw a Blue R34 GTR (not the same on as we were cruising with) turn right off Goodwood Rd onto Springbank + a lot of other randoms - was definately a good day for it. A few pics below of our little group at Windys today.
that would have been me ...
i pass there every day, what were you in?
was out for a drive tonight about 11:30 and ended up following two other r32 gtst's one maroon and one black, pulled up at the lights with the guys in the black said they were on the way home from the charity cruise, hope you boys got home hassle free. :D
you drove up for a little bit, then pulled over... i was in the filthy dirty blue AU firmont with bodykit and rims
yeah needed to check something in the back hadn't moved .....
someone beeped as i got out the car though ..... was that you?
Awesome pics of the gtr's Craig,shame about the white r33 cramping your style...
Could easily crop it out of the photos..
Shame I had to work,Ryan said you lads had a good day
silver evo8 in the carpark at work last night too,with bronze cr Kai rims,old chap driving wasn't afraid to get into either wen they left the restaurant,sounded mental!
Ah that was you. :D You change cars like you change your underwear lol. I looked across to see if i knew who it was and didnt ever realise it was you. :(
haha nah driving parents car till the GTR can be driven on the road
Spotted Jas (JAS 033) doing a chainers run today.
Also an R34 GTR V-Spec 2 Nur.... O! M! G! That thing is HAAAWT!! Tastefully lowered, GTR rims, that blue/green colour, no words to say how nice it was, would have stood there and stared at it all day if i could.. Bugger a 35, I much rather one of them :( had S series plates.. Maybe lives down south considering it was at a local IGA...
Also an R34 GTR V-Spec 2 Nur.... O! M! G! That thing is HAAAWT!! Tastefully lowered, GTR rims, that blue/green colour, no words to say how nice it was, would have stood there and stared at it all day if i could.. Bugger a 35, I much rather one of them :D had S series plates.. Maybe lives down south considering it was at a local IGA...
Hey Jarrad, think you'll find it lives around the corner from you! Do the pics above look familar?? :( (Oh and it's not a NUR spec unfortunately).
Edited by 32godzilla
Serious? A hot as car like that one in Morphett Vale? LOL
Could have sworn it was a Nur, but alas, too good to be true.. Parked 2 spaces away from it, should have waited for the owner to come out :rofl: and then you tell me the owner lives around the corner, what a coincedence.
Oh, btw, you still live down the road? Havnt seen you around for quite awhile..
Also today i may have spotted MSTR34 near the round about on Chandlers Hill Road, sun was in my eyes so only saw the rear and an M at the start of the plates lol
should have waited for the owner to come out :( and then you tell me the owner lives around the corner, what a coincedence.
Gee this is panning out like the movie 'The Usual Suspects'!!! Yes I'm still down the road....... :rofl:
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
