Saw the failspec red r34 with those 20" chromies on Bridge road this morning. Nearly made me want to stab myself in the eyes. Ugliest POS on the road...
-D
Thats BALLERZ... he's hektik
purple R34 GTR, SAU-34 belching black smoke ,running a bit rich while cold on south rd I was in front of you at the lights
Hey mate - might be the fact I hadn't driven it in 10 days! But yes definately cold.
Jeremy thats been me in the white commo thats been waving at you :P
haha yeah felt like an idiot cos i thought you may have been waving at someone else haha but saw your face in mirror.. took me ages cos was listening to the chick in my car :) looked like you was going to autobarn
Silver 33 was me. My car really needs a wash - the shine off of yours put it to shame!!
haha should see it now.. f**ken birds in tree above my car grrr
saw and drove with and behind dark 33 all the way from novar gardens to marion, didnt look, smile or nod once
white r32 gtst near that fitness shop diagonal/ sturt intersection
10:45am
Black R34 4-door with factory position foglights, factory rear wing, no kit, silver meshies, privacy glass @ the rear.
Pulled up next to me at the Byards/Kenihans Lights, I saw it in my side mirror, and subconsciously thought I was seeing the reflection of my car ( I do check it out in windows all the time haha), then realised as I turned left and it turned right that there were a lot of things that didn't match...
Mine would be the the one with full factory kit, factory wing, and R33 GTR wheels.
Spotted 'RIPP3R' and black R33 along diagonal road heading past Marion, was in the left lane turning into Fitness First
ah you the white 32 i mentioned above..
saw "dare ya" parked out front of tyre power blackwood
RIPP3R going down Flagstaff Rd about 6 ish
And a R34 GTR, 'SAU-34' On South Rd/Daws Rd Intersection about 11:45
Was that you that I saw turn right next to me onto Daws Rd??
Edit: While I'm at it saw that killer black 34 GTR with the red leather seats on Churchill Rd around 4pm - so fat! :(
And a nice black stagea near my work with plates GTS-xxx
Oh and lucky last I saw Chad in the Stag on Panalatinga around 5.30pm, was in old man's Territory.
Edited by 32godzilla
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
