Id say there is a few Blue R32's getting around Adelaide...
i have a blue 4dr but wasnt there. so wasnt me :O
seen HSVEEATER today :O:O
also that tool in the black 3000gt. so jdm yo with all my stickers and pot rivited on rear spoiler.
look at me i have a bov and cant drive. :domokun:
yeh i was doin laps chad, some weird cop action on cnr of king willy and north tce, had to keep going straight then right around down hindley and jeffcott st home.
spotted a black R33 at bp west tce, was N/A, loud exhaust. had a quick chat to me, passenger was hot :)
havent mounted the aerial yet. got a bracket, gotta buy the right base unit with a plug to suit the UHF im getting (and Dick Smith's cant tell me the type of plug that GME use as they dont stock it)
Yeah, the insurance thing? White wheels?
insurance thing? huh?
Kellie msgd me to say she saw my car on the DA coverage - was entered in the small show n shine there, but not sure what insurance thing you talking bout.
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
