i know its not a skyline but worth the mention. a delorean at the first choice on N.E road. i didnt think there were any in S.A that were registered older guy driving it and still left hand drive. nice looking classic trying to upload pics from phone
think i seen this in regency park about a month ago. just casually driving along while i was heading back to the depot
dont forget left hand drive with lift up doors, needs more room on the left to get out and get the door open and up
common misconception. because the doors are hinged closer to the centreline of the car, they actually use less space opening than a conventional door. probably just parked that way due to the left hand drive alone
-D
Spotted a gunmetal 32 GTR with bronze TE37's performing a UTurn on Grange road around 4:45pm last night. Then a gunmetal MSPEC 32 on south road around 10m later :)
Anyone from here?
Anyone from here?
Yeah that was me heading over to see the missus after work. Didn't see you though mate would have given you a salute :)
Couldn't have been you, Unless you resprayed your GTR Gunmetal recently :D?
Pretty sure it's still silver, must be another 32 with bronze te37's getting around me area. I didnt see it last night.
Saw a very clean looking wine red 32R heading down south road as I was waiting to turn onto grange road about 4ish this arvo.
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
