theres a red one that some guy owns up the road from me, such a beautiful thing
Had a silver 35 GTR pull up beside me in the city today for a chat...
Had standard SA plates..
Gorgeous car..
wondering if its someone on here?
Hey Matty, did you drive past the Coke a' Cola factory this afternoon headed South? May have been behind ya, don't see many of those 4wd's around these days!
Nah, i was on South Road for most of my southbound trip, headed back via tyrepower to see if my winch had rocked in
Spotted few varieties:
- Black Stagea sounding like a jet-plane taking off on Heath Street in Lonsdale
Could have been mine coz i work in lonsdale :yes:
Would have been me thinks, would have been around 5pm, heading down Heath Street headed to Lonsdale Highway direction. Was getting into the jeep wrangler and caught the ear :P
Spotted a black 35 this morning on a trailer heading right past Ikea's loading dock, then back the other way about half hour later. Was being towed by a silver 4WD.. Was between 6 and 7am this morning..
A red 34 getting it sideways in the wet next to the airport around 8.30ish this morning.
And a blue Evo heading up towards Windies around 5.30 yesterday arvo, smelt like it was running E85.. Very quick!
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
