Well let's face it if you can afford these cars it would be easier to simply own both. Audi would be nice but I wonder how much a full service would cost.
Back on topic, spotted DRFT32 at the servo. Had a chat with the bloke, I suspect that cars had a hard life! anyone who knows the car would understand! :P
If you were at the point where you could afford to own the Audi flagship car, you'd like just head to the dealer, swipe your Amex black, and get your accountant to find a way to write it off as an expense.
In plain English, if you have to ask, you can't afford it.
And I would still do disgusting unforgivable things to own an R8.
iam with u on that one :worship: kick ass car
i seen that aswell today damo aparently its been there a little wile but has 3 nice roh modenia's but no stagger so they can stay there :ph34r:
did u also see the fat homeless guy sleeping half on the road and half on the footpath gotta love the port
Edited by JETURBO
LOL Steve, a Chev Challenger is like saying a Holden Charger :P
you're just generalizing Luke...........it's not that bad, surely :ninja:
No, not at all
I'll never forget the day on a job I was on when a one eyed Port supporter was drinking down at the Alberton after work. He came out after a short stint to find his work ute gone :laugh: He came back to work a few days later, with a new ute, and vowed never to step foot in that pub again or to support "that feral mob" :rofl:
LOL Pete its both do some research
http://lmgtfy.com/?q=chev+challenger
I actually followed your link Steve where it shows pictures of a Chev Camaro, and a Dodge Challenger............2 different cars bud regardless of what your search comes up with
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
